Xometry is proud to support US Department of Defense and Government manufacturing. A subset of its supplier network has a JCP certification. JCP certifications are often required for the handling of DOD CUI/CTI with a Distribution Statement.
JCP stands for Joint Certification Program, and eJCP stands for Enhanced Joint Certification Program. An eJCP allow suppliers to access DOD/DND unclassified export-controlled technical data and perform work for the Defense Logistics Agency (DLA). An active CAGE code and completed form DD 2345 is required for partner flow-down requirements if JCP is selected.
For an eJCP, an Approval Memorandum** for that supplier is required by Xometry and should be noted in the project drawings. Learn more about the JCP program.
**eJCP Approval Memorandums are issued after a Supplier completes their DIBBS registration and verifies their physical address in DIBBS. Read more about DLA Export Control Data Access and Enhanced Validation.
Customers may request that JCP-approved suppliers do their work through their representatives or the online platform.
Documents required by Xometry for supplier approval:
Example DD 2345 document:
Example eJCP Approval Memorandum:
