Beta-Feature
Manage your Jobs the way you do in the Shop
- Specify which Processes your shop does to control the 'Process' or 'Line Item Type' options when adding In-house Jobs
- Hiding a Process
- Removes it from the 'Line Item Type' option when adding Line Items to In-house Jobs
- A hidden Process can be re-added (or unhidden) using the '+ Add A Process' button
- Adding a Process
- Adds it to the 'Line Item Type' option when adding Line Items to In-house Jobs
- Specify the default production workflow for a Process so that when a Line Item is added to a Job, it gets that particular sequence of production steps automatically
- Click 'Edit Workflow' to select existing production steps or create new ones, and add them to the workflow
3. After you create an In-house Job, you can always make edits to a specific Job's Workflow. When editing, you have the ability to pull from the Default Process Workflow (in case you have made updates since the Job was created), you can save the Job Workflow Edits to just the Job, or save to the Process Default for future use. See more on Job Workflow Edits
If you are interested in learning more about Beta-Feature Process Management and Workflow Editing to manage your In-house Jobs, feel free to reach out to matt.lerner@xometry.com to ask questions or request a walk-through.
