Learn more about our FDM 3D printing services
Fused Deposition Modeling (FDM) 3D Printed Materials
Our FDM materials are grouped by their intended function and material characteristics, including: General Purpose, High Performance/Engineering grade, and Specialty materials. Stratasys-branded materials are always printed on Fortus FDM platforms, while generic ABS, ASA, PLA, PETG, and Nylon 6 CF may be printed on other platforms.
Looking for data sheets? Visit our FDM page and browse the material tables.
General Purpose Materials
- ABS (General Purpose): A generic ABS for general-purpose applications; available in Black, Blue, Dark Grey, Ivory, Red, and White.
- ASA (General Purpose): A generic ASA for general-purpose applications; available in Black, Dark Blue, Dark Gray, Light Gray, Green, Ivory, Orange, Red, White, and Yellow.
- PLA (General Purpose): An economical, rigid plastic for low-wear indoor parts, concept models, and prototyping. PLA is very popular due to its high use in desktop and hobbyist 3D printers. Available in Black, White, Red, and Blue.
- PETG: PETG is a robust and highly versatile 3D printing material that effectively bridges the gap between the ease of printing offered by PLA and the mechanical strength and durability of ABS. Available in White, Black, Dark Grey, Blue, Red, and Yellow.
- Nylon 6 CF: A generic Nylon 6 that has been reinforced with carbon fiber chop. The carbon fiber filler significantly increases the stiffness and strength of the material. Available in Black.
- Stratasys ABS-M30: Great general-purpose material available in Black, White, Red, Blue, Dark Grey, and White. Ideal for functional prototypes and low-volume production.
- Stratasys ABS-CF10: Combines standard ABS material with 10% chopped carbon fiber by weight, resulting in a 50% stiffer and 15% stronger ABS than the standard option. Available in Black.
- Stratasys ASA: Matches or exceeds the properties of standard ABS and has higher UV stability. Ten colors are available. A strong "go-to" general-purpose material.
High Performance Engineered Materials
- Stratasys Nylon 12: Nylon is a ductile and chemical resistant plastic great for rugged applications. This black material is flexible enough for snap fits and is useful in environments that experience high shock and vibration.
- Stratasys PC (Polycarbonate): With almost twice the tensile strength of ABS, polycarbonate has superior mechanical and structural properties. Used widely in automotive, aerospace, and other applications that require durability and stability.
- Stratasys PC-ABS: The best of both PC and ABS. Higher-strength engineering thermoplastic with slightly more flexibility than standard polycarbonate.
- Stratasys ULTEM 1010: Flame-retardant high-performance thermoplastic for end-use parts. Certified for food contact and biocompatibility. Widely used in the aviation and transportation industries due to the UL94 classification.
- Note: Also available in certified grade as "ULTEM 1010 CG" for food contact (NSF 51) and biocompatibility (ISO 10993/USP Class VI) compliance.
- Stratasys ULTEM 9085: Flame-retardant high-performance thermoplastic for complex end-use parts. Heavily used in transportation and aerospace, it can also be applied in high-heat mechanical environments.
- Stratasys Antero 800NA: A high-performance PEKK-based thermoplastic renowned for its exceptional chemical and mechanical properties, making it an excellent choice for demanding engineering applications.
- Stratasys PAEK VICTREX AM 200: A specialized grade of PAEK, formulated as a unique Low-Melt PEEK (LMPAEK) polymer explicitly optimized for 3D printing. Printed parts retain the high strength, superior chemical resistance, and extreme thermal stability of traditional PEEK, while having a lower risk of build failure and being easier to process.
Speciality Materials
- Stratasys ABS-ESD7: Static dissipative ABS ESD (electrostatic dissipative) material. Great for jigs and fixtures in electronic assembly environments.
- Stratasys Antero 840CN03: A high-performance thermoplastic is based on the PEKK polymer family, but features inherent Electrostatic Dissipative (ESD) properties.
- Stratasys ABS-M30i: Biocompatible ABS material can be gamma or EtO sterilized (ISO 10993 USP Class VI). Well suited for conceptual modeling, tools, and guides.
- Stratasys PC-ISO: Biocompatible PC material can be gamma or EtO sterilized (ISO 10993 USP Class VI). Well suited for food and drug packaging as well as medical device manufacturing.
Additional Resources:
Learn more about our finishes
Visit our 3D Printing Services page
