Register for a United States Partner Account
The first step to becoming an approved partner is to follow the registration process, linked below. This will create a partner account with relevant partner details, allow you to upload financial documents and industry certifications and provide next steps in the onboarding process.
🔗Become a Partner
Register for an International Partner Account
Select the appropriate country of your operations from the list below and follow the instructions on the subsequent registration page.
Onboarding Requirements by Process
Machining
Current capabilities offered:
- CNC
- Sheet Cutting
- Sheet Metal
- Tube Cutting
- Tube Bending
To be eligible for our Machining processes, the following conditions must be met:
- Must have GD&T Experience
- The facility cannot be a shared space with other companies; no makerspaces
- Partner must have at least one mill or lathe machine
- Partner must own at minimum for inspection equipment:
- Micrometer
- Caliper
- Set of standard thread and pin gages
- Surface Plate
- Height gage
If your shop does not currently meet the requirements outlined above, we will happily retain your application details on a waitlist. Should your operations evolve in compliance with one or more of the requirements above, please update your shop details to resume your application. We appreciate your interest.
- SLS
- MJF
- FDM
- Polyjet
- SLA
- Carbon DLS
- DMLS
- Metal Binder Jetting
To be eligible for our Additive processes, the following conditions must be met.
- Must have an established internal or third party QMS (copy required at time of application)
- Must be located in a commercial building
- Must offer one or more of the printing processes and materials included in Xometry’s quote offerings
- Must have applicable calibrated inspection equipment to ensure parts conform to customer requirements.
Visit the Additive Partner Onboarding Guide for additional details.
Urethane Casting
To be eligible for our Urethane Casting processes, your primary business address must be a commercial location, not a garage shop or residential shop.
Visit the Urethane Casting Partner Onboarding Guide for additional details.
Other Tooling Manufacturing
We offer the following capabilities:
- Injection Molding
- Die Casting
- Stamping
- Metal Extrusion
- Plastic Extrusion
- Compression Molding
To be eligible for our Other Tooling processes, the following conditions must be met.
- Must possess an establishedQMS certification
- Must be rapid (1-3 weeks) tool build capable
- ITAR and/or JCP Certification
Visit the Injection Molding Partner Onboarding Guide for additional details.
Submitting the W-9
To join the partner network you will need to upload a W-9 for our records. If you are having trouble locating or uploading your W-9, please click here to submit one via Docusign.
See below for an example of a filled out W-9 form:
For your W-9 to be valid, it must include the following:
Depending on companies' status:
- Individual or Sole Proprietor - first and last name
- Company - legal business name as it appears on SS4.
- Individual - should be left blank
- Company - unless there is a registered DBA, this line should be blank
Your Federal Tax Classification
- Check the box associated with your IRS registration/SS4 form.
- Exceptions
- Company Address
SSN or EIN
- ONLY use your Social Security Number when you check the first box (in number 2) and you are an individual. Sole Proprietors should have an Employer Identification Number (EIN). If you are a Limited Liability Company (LLC) make sure you indicate on the line at the far right if you are an S or C Corp or an LLC. This determines whether you will receive a 1099 or not.
- Signature and Date
