Sheet metal services can include forming/bending [note: this should link to the Sheet Metal Fabrication page “What is Sheet Metal Forming?” section, but there’s no HTML anchor or ID in that section], welding, custom finishing, and installing inserts such as PEM fasteners. Read more about fabricating from aluminum.
If you do not see the material stock you are looking for, please choose "Custom" under the material drop-down on your quote page and submit for an expert engineering review once you have specified features, tolerances, inspection needs, and quantities required.
See the most common available sheet gauges.
Learn more about our finishes
