A variety of CNC machined metal part options are available for an instant online quote. If you do not see the material stock you are looking for, please choose "Custom" under the material drop-down on your quote page and submit for an expert engineering review once you have specified features, tolerances, inspection needs, and quantities required.
Nitronic 60: A stainless steel, also known as UNS S21800 or 218 stainless, is a high-performance metal with high temperature and wear resistance. Its corrosion resistance is superior to 300-series stainless steel. Nitronic 60 can maintain its strength to over 1800°F and is common in aerospace for flight parts.
Stainless Steel 15-5: Offers corrosion resistance similar to Stainless 304. Improved workability, hardness, and high corrosion resistance.
Stainless Steel 17-4: A high-strength, corrosion-resistant stainless alloy. Easily heat treatable. Typically used in medical equipment.
Stainless Steel 18-8: One of the most commonly used stainless steels. Also known as Stainless Steel 304.
Stainless Steel 303: A machinable, corrosion-resistant steel. (View spec sheet)
Stainless Steel 304: A machinable, corrosion-resistant steel.
Stainless Steel 316/316L: A highly corrosion-resistant steel popular for medical devices. (View spec sheet)
Stainless Steel 410: A wear and corrosion-resistant stainless steel used in fasteners, cutlery, nozzles, and tools. 410 stainless is one of the most commonly used 400-series alloys and is often heat treated. 410 stainless steel is magnetic.
Stainless Steel 416: Easily machinable but can be heat-treated to increase strength and hardness. Low corrosion resistance.
Stainless Steel 420: Contains more carbon than Stainless 410 to give it increased hardness and strength when heat treated. Offers mild corrosion resistance, high heat resistance, and improved strength.
Stainless Steel 440C: One of the hardest stainless steels with a Rockwell of 58-60 HRC after heat treatment. 440C is common in bearing applications where high
Learn more about our finishes
Visit our CNC machining services page
