A variety of CNC machined metal part options are available for an instant online quote. If you do not see the material stock you are looking for, please choose "Custom" under the material drop-down on your quote page and submit for an expert engineering review once you have specified features, tolerances, inspection needs, and quantities required.
Aluminum 6061: Our most popular machined metal. Easily machined and lightweight, perfect for prototypes, military, and aerospace applications. (View spec sheet)
Aluminum 2024: Used when a high strength-to-weight ratio is required, such as for gears, shafts, and fasteners. It is non-magnetic and heat treatable.
Aluminum 5052: Corrosion-resistant aluminum is frequently used in sheet metal applications.
Aluminum 6063: Commonly used outdoors as architectural trim, railings, and door frames, 6063 aluminum has better machinability than 3003. It is non-magnetic and heat treatable.
Aluminum 7050: Preferred over 7075 aluminum for use in structural applications, 7050 is a high-strength material that resists fatigue and stress cracking. 7050 is non-magnetic and heat treatable
Aluminum 7075: Harder and higher strength aluminum alloy good for high-stress parts.
Aluminum MIC-6: A cast aluminum plate often used for tooling and base plates.
Learn more about our finishes
Visit our CNC machining services page
