The best and fastest way to get into contact with someone from our team is by creating a discussion!
Creating a New Discussion
To create a new discussion, begin by clicking here, scroll down, and select Create A Discussion.
Once you select the Create A Discussion you will be brought to this screen where you can begin writing your new discussion post.
Category
To begin, choose a relevant category for your discussion. Click on the "Select a category" dropdown to browse through the various options available in the Community. Pick a category that aligns with the topic of your new discussion. For instance, if you're sharing tips and tricks, you may select the Partner Tips and Tricks category.
Discussion Title and Description
To begin, choose a clear and informative title for your new discussion that will give other Community members an idea of what to expect when they read it.
Once you have created your title, you can proceed to write your discussion description. You have the option to insert emojis, images, embedded links and attachments in the bottom portion of the description.
Tagging
Tags are a helpful feature that enables community members to add keywords to their discussions. These tags help label specific content, making it easier to find the article through the search bar. If you want to tag your article, simply click on "Show popular tags" and select the tags that relate to your discussion.
Posting
Finally, after you have chosen your category, given a title, and added a description to your discussion, you can proceed to post it. Simply click the "Post Discussion" button located beneath the description. Remember that you have the option to save your discussion as a draft. To access your drafts, click on your profile photo located in the top right corner.
Commenting on Discussions
To add your thoughts to an ongoing conversation, simply click on the discussion you want to participate in. Once you're in the discussion, you'll see a section labeled "Leave a comment." This is where you can share your feedback, ideas, or opinions. For example, in the "Friday Music Suggestions" conversation shown below, you can add your own music recommendations.
Once you've written your comment, just click the "Post Comment" button to submit it. You can use emojis, images, links, and attachments just like in the discussion description. Other members of the community will be able to read your comment and respond to it.
