Xometry offers many materials in different processes that can withstand higher levels of heat. The material, process, and temperature a part can withstand before melting are listed below. The materials are thermoplastics made using Carbon DLS, SLA, SLS, HP MJF, or FDM processes.
SLS Nylon 12
Material: PA 2200 (Durable White Nylon)
Process: SLS
Melting Temperature (°C/°F): 176 / 349
SLS Nylon 12, Flame Retardant (FR)
Material: PA 606-FR
Process: SLS
Melting Temperature (°C/°F): 180 / 356
SLS Nylon 12, Glass-Filled
Material: DuraForm GF or equiv.
Process: SLS
Heat Deflection Temperature (°C/°F): 179 / 354
SLS Nylon, Carbon-Filled
Material: PA 602-CF
Process: SLS
Heat Deflection Temperature (°C/°F): 175 / 347
SLS Nylon, Aluminum-Filled
Material: PA 602-CF
Process: SLS
Heat Deflection Temperature (°C/°F): 180 / 356
SLS Nylon, Mineral-Filled (HST)
Material: PA 620-MF
Process: SLS
Heat Deflection Temperature (°C/°F): 184 / 363
HP MJF Nylon 12
Material: HP 3D High Reusability PA 12
Process: HP Multi Jet Fusion (HP MJF)
Melting Temperature (°C/°F): 187 / 369
Stratasys Ultem 1010
Material: Ultem 1010
Process: FDM
Glass Transition Temperature (°C/°F): 215 / 419
Stratasys Ultem 9085
Material: Ultem 9085
Process: FDM
Glass Transition Temperature (°C/°F): 186 / 367
Stratasys Nylon 12
Material: Nylon 12
Process: FDM
Melting Temperature (°C/°F): 178 / 352.4
SLA Accura Bluestone™
Material: Accura® Bluestone™
Process: SLA
Heat Deflection Temperature (°C/°F): 284 / 543 *
SLA Formlabs High Temp
Material: Formlabs High Temp
Process: SLA
Heat Deflection Temperature (°C/°F): 238 / 460 *
SLA Somos PerFORM
Material: Somos PerFORM
Process: SLA
Heat Deflection Temperature (°C/°F): 268 / 514 *
* HDT after thermal post-cure at @ 0.46 MPa (66 psi).
Watch our video showcasing some 3D-printed plastics under intense heat. Learn more about this engineering challenge here.
Visit our 3D printing services page.
