Watch our video on PolyJet 3D Printing:
Xometry offers PolyJet rigid photopolymer (PJ3D), which is a 3D printing technology that builds parts out of a UV-curable resin with high detail and the ability to apply different material properties. PJ3D works similar to an inkjet printer, where thousands of micro-dots of material are deposited and cured, layer by layer, to build a part from the bottom to the top.
This process is best for concept models, test-fitting parts, or creating multi-material parts that simulate the feel of the eventual end-use part, such as applying a rubbery overmolded feature over a rigid one. The ability to have both rigid and rubber-like features on one print via multi-material printing is one of the most overlooked advantages of PolyJet technology.
At Xometry, our PolyJet machines also support full-color prints, rendering hundreds of thousands of colors and textures in a single print. Simply upload a compatible CAD file with color information (we recommend .3MF) and select Multi-Color, CAD-Defined from the material drop-down.
Tolerances and Limitations
Here are the basic tolerances and limitations of PolyJet:
- +/- 0.004” for the first inch is typical, plus +/- 0.002” for every inch thereafter.
- Build area up to 19 x 15 x 7"
- Rubber-like materials approximate shore A values and may vary between geometries.
- PJ3D prints in 0.0012" layers (30 μm), making it a very detailed and accurate process.
If you plan on painting your PolyJet part, it is recommended to go over it thoroughly with a wet abrasive pad to remove remnants of its gel-like support material. If your part requires more mechanical strength or high durability, you may want to consider other processes like SLS, FDM, or SLA.
Visit our 3D printing services page.
