Material Details
Process - Sheet Metal - Bent
Material - Aluminum 5052
Dimensions - 6" x 11.75" sheet (Note: thickness varies based on whats stocked)
Finish - As Milled, Deburred and Oil-Free
Shipping - Fedex Ground
Test Part Files
Your test part files will have all the information you need to complete your test part. In this file you will find a test part drawing, balloon drawing, CAD file of the test part, and a copy of the test part guidelines and instructions with your inspection report on the last page.
Download Sheet Metal - Bent Test Part Packet and Drawings →
Note: The test part files are available as a zipped folder and you must extract the files in order to view. To unzip the entire folder, right-click the file to select Extract All, and then follow the instructions to select Extract in the following prompt.
I've Started Making the Test Part
What if I run into problems?
If you run into any quality or technical questions once you start making your test part attend our Daily Support Hours. Here you will get to speak with our Xometry experts and the people who will be inspecting your test part when it is sent back.
Once I finish, whats next?
Once you've finished your test part you'll need to send it back. See the Returning Your Test Part section of the Test Part Guidelines and Instructions article for return instructions.
