CNC Mill Test Part - Xometry's Manufacturing Community
<main> <article class="userContent"> <h2 data-id="material-details">Material Details</h2><p><strong>Process - </strong>CNC Mill</p><p><strong>Material -</strong> stainless steel 316 (Provided by <a href="https://www.xometry.com/supplies/" rel="nofollow noreferrer ugc">Xometry Supplies</a>)</p><p><strong>Dimensions - </strong>1" x 2" x 3"</p><p><strong>Finish - </strong> As Milled, Deburred and Oil-Free</p><p><strong>Shipping -</strong> Fedex Ground</p><p><strong>Note: <em>Delrin is an acceptable alternative material for the CNC - Mill test part ONLY. If you choose to use Delrin you will be responsible for supplying the material.</em></strong></p><h2 data-id="test-part-files">Test Part Files</h2><p>Your test part files will have all the information you need to complete your test part. In this file you will find a <strong>test part drawing, balloon drawing, CAD file of the test part, and a copy of the test part guidelines and instructions with your inspection report on the last page</strong>.</p><p><a href="https://340051.fs1.hubspotusercontent-na1.net/hubfs/340051/%5BP%5D%20Partner+Supplier/Partner%20Files/New%20Partner%20Onboarding/Xometry%20CNC%20Mill%20Test%20Part%20Package.zip" rel="nofollow noreferrer ugc">Download CNC - Mill Test Part Packet and Drawings →</a></p><p><strong>Note</strong>: <em>The test part files are available as a zipped folder and you must extract the files in order to view. To unzip the entire folder, right-click the file to select Extract All, and then follow the instructions to select Extract in the following prompt.</em></p><h2 data-id="step-by-step-tutorial-video">Step-by-Step Tutorial Video</h2><p>To help set you up for success, we've created a step-by-step walkthrough of Todd White, CEO of Todd White Metal Works, machining the test part! This should help you as you start your journey with Xometry!</p><p><strong>Note:<em> </em></strong><em>The test part that we ask you to complete differs from the one shown below. The video playlist shown below shows a good step by step process for the test part but is not the same as the one you are asked to complete. </em><strong><em>Make sure to reference your files as they will be different.</em></strong></p><div class="js-embed embedResponsive" data-embedjson="{"body":"In this 18 part video series, Todd White from Todd White Metal Works walks you through the Xometry CNC Mill Test Part machining process. He covers everything...","photoUrl":"https:\/\/i.ytimg.com\/vi\/T6BfFKxYCsw\/hqdefault.jpg?sqp=-oaymwEWCKgBEF5IWvKriqkDCQgBFQAAiEIYAQ==&rs=AOn4CLCcXcPe4ZTV52Sn1yq5Oki0EB9qNg&days_since_epoch=19276","url":"https:\/\/www.youtube.com\/playlist?list=PLzpha71bHNxx3_wB-CgwZrJySkGjsGxFE","embedType":"link","name":"Xometry Training: CNC Mill Test Part"}"> <a href="https://www.youtube.com/playlist?list=PLzpha71bHNxx3_wB-CgwZrJySkGjsGxFE" rel="nofollow noreferrer ugc"> https://www.youtube.com/playlist?list=PLzpha71bHNxx3_wB-CgwZrJySkGjsGxFE </a> </div><h2 data-id="i've-started-making-the-test-part">I've Started Making the Test Part</h2><h4 data-id="what-if-i-run-into-problems">What if I run into problems?</h4><p>If you run into any quality or technical questions once you start making your test part attend our <a href="https://community.xometry.com/events/category" rel="nofollow noreferrer ugc">Daily Support Hours</a>. Here you will get to speak with our Xometry experts and the people who will be inspecting your test part when it is sent back.</p><h4 data-id="once-i-finish-whats-next">Once I finish, whats next?</h4><p>Once you've finished your test part you'll need to send it back. See the <a href="https://community.xometry.com/kb/articles/610-test-part-guidelines-and-instructions#returning-your-test-part" rel="nofollow noreferrer ugc">Returning Your Test Part</a> section of the Test Part Guidelines and Instructions article for return instructions.</p> </article> </main>
