Additional Inspection Documentation - Xometry's Manufacturing Community
<main> <article class="userContent"> <h2 data-id="certificate-of-conformance-(coc)">Certificate of Conformance (CoC)</h2><ul><li>Required for all part IDs, <strong>if indicated on the PO </strong></li><li>Pre-populated by Xometry and downloadable from the job board </li><li>Once completed, the CoC must be uploaded to the job board and included in the part shipment</li></ul><div class="embedExternal embedImage display-large float-none"> <div class="embedExternal-content"> <a class="embedImage-link" href="https://lh3.googleusercontent.com/AtV5lTx9-svfzaJX9YMsAfxTwqHxnX4FdLx4zeMQdZQ2iC42sVT2Zek39LONKNXbejJSfDeTbEIq1F_bbHCE2A4h3UA8lZuugzxKeK9w60nE77N9b5SfGN3HdIoGQJsz01xJrgCI=s0" rel="nofollow noreferrer noopener ugc" target="_blank"> <img class="embedImage-img" src="https://lh3.googleusercontent.com/AtV5lTx9-svfzaJX9YMsAfxTwqHxnX4FdLx4zeMQdZQ2iC42sVT2Zek39LONKNXbejJSfDeTbEIq1F_bbHCE2A4h3UA8lZuugzxKeK9w60nE77N9b5SfGN3HdIoGQJsz01xJrgCI=s0" alt="AtV5lTx9-svfzaJX9YMsAfxTwqHxnX4FdLx4zeMQdZQ2iC42sVT2Zek39LONKNXbejJSfDeTbEIq1F_bbHCE2A4h3UA8lZuugzxKeK9w60nE77N9b5SfGN3HdIoGQJsz01xJrgCI=s0" height="859" width="624" loading="lazy" data-display-size="large" data-float="none"></img></a> </div> </div> <p><em>Note: The highlighted sections are required to be completed by the partner. All other fields will be pre-populated by Xometry. </em></p><p>You can download your pre-populated CoC in the job details section of each part.</p><div class="embedExternal embedImage display-large float-none"> <div class="embedExternal-content"> <a class="embedImage-link" href="https://us.v-cdn.net/6032202/uploads/MGTJ90PELS3U/untitled.png" rel="nofollow noreferrer noopener ugc" target="_blank"> <img class="embedImage-img" src="https://us.v-cdn.net/6032202/uploads/MGTJ90PELS3U/untitled.png" alt="untitled.png" height="691" width="1600" loading="lazy" data-display-size="large" data-float="none"></img></a> </div> </div> <p>Each CoC must be printed and signed or signed using your own e-signature software, and then scanned and uploaded to the portal/included in the part shipment.</p><h2 data-id="finishingplating-certification">Finishing/Plating Certification</h2><ul><li>Must contain the exact specs that the customer requested on the drawing or PO </li><li>Must have a signature </li><li>Must have a Xometry Part number or drawing number </li><li>Must list other finishes - include any heat treatments or other specialty testing that was done to parts - must be listed</li></ul><div class="embedExternal embedImage display-large float-none"> <div class="embedExternal-content"> <a class="embedImage-link" href="https://lh6.googleusercontent.com/TMHAAQ-JvPkp4KyUD1WPm0zJOm7UdvuavD9eyYaBYCnc5KKxtsbVd40qPi8yr47fYanzlAuvp6RlIiHhp5xCZCruS8yLN1pLpdaILXQo5ffZRehpwPHmaGbjiFQNRt1-qXHVvwgo=s0" rel="nofollow noreferrer noopener ugc" target="_blank"> <img class="embedImage-img" src="https://lh6.googleusercontent.com/TMHAAQ-JvPkp4KyUD1WPm0zJOm7UdvuavD9eyYaBYCnc5KKxtsbVd40qPi8yr47fYanzlAuvp6RlIiHhp5xCZCruS8yLN1pLpdaILXQo5ffZRehpwPHmaGbjiFQNRt1-qXHVvwgo=s0" alt="TMHAAQ-JvPkp4KyUD1WPm0zJOm7UdvuavD9eyYaBYCnc5KKxtsbVd40qPi8yr47fYanzlAuvp6RlIiHhp5xCZCruS8yLN1pLpdaILXQo5ffZRehpwPHmaGbjiFQNRt1-qXHVvwgo=s0" height="521" width="624" loading="lazy" data-display-size="large" data-float="none"></img></a> </div> </div> <h2 data-id="material-certificationtest-report">Material Certification/Test Report</h2><p><strong>Standard Material Certifications</strong></p><p>Must state both mechanical and chemical properties of the material, lot or heat number, and the specification which the material complies with (AMS, EN, ASME, ASTM, etc.).</p><p><strong>Domestic Material Certifications</strong></p><p>Same requirements as standard<strong> BUT</strong> must also show melt location is in the USA.</p><p><strong>DFARS Material Certifications</strong></p><p>Same requirements as standard <strong>BUT</strong> must also show Country of Origin (COO) on certification, proving material is from a DFARS compliant COO. Below is a list of DFARS compliant countries.</p><div class="embedExternal embedImage display-large float-none"> <div class="embedExternal-content"> <a class="embedImage-link" href="https://lh4.googleusercontent.com/vDEEFPooLXVPl5N3RDmnAy_xlPdor1wboQnELiKsQxXNYtiellhqyLvdSBbRrxgag8IDIZ0csInYAS8yUnVIzIi69esP--fcjnoRLai_Hp9qfNpZpJrL0UCJA67q15gOyNYN0vpr=s0" rel="nofollow noreferrer noopener ugc" target="_blank"> <img class="embedImage-img" src="https://lh4.googleusercontent.com/vDEEFPooLXVPl5N3RDmnAy_xlPdor1wboQnELiKsQxXNYtiellhqyLvdSBbRrxgag8IDIZ0csInYAS8yUnVIzIi69esP--fcjnoRLai_Hp9qfNpZpJrL0UCJA67q15gOyNYN0vpr=s0" alt="vDEEFPooLXVPl5N3RDmnAy_xlPdor1wboQnELiKsQxXNYtiellhqyLvdSBbRrxgag8IDIZ0csInYAS8yUnVIzIi69esP--fcjnoRLai_Hp9qfNpZpJrL0UCJA67q15gOyNYN0vpr=s0" height="141" width="624" loading="lazy" data-display-size="large" data-float="none"></img></a> </div> </div> <p><br></p> </article> </main>
