Sheet Metal - Flat and Cutting Test Parts - Xometry's Manufacturing Community
<main> <article class="userContent"> <h2 data-id="sheet-metal-flat-test-part">Sheet Metal - Flat Test Part</h2><p>You will receive an email with downloadable test part files when your test part material is shipped. You will need to request your test part through the link below in order to review the test part files. </p><p>Please note that it is a violation of our <a href="https://xometry-marketing.cdn.prismic.io/xometry-marketing/c1bb43ca-9bc0-46eb-b763-fb9a9a2f675e_Partner+Terms+and+Conditions+10+28+20.docx-2.pdf" rel="nofollow noreferrer ugc">Partner Terms and conditions</a> to subcontract out the test part.</p><ul><li><strong>Process - </strong>Sheet Metal - Flat</li><li><strong>Material -</strong> Aluminum 5052 Sheet (Provided by <a href="https://www.xometry.com/supplies/" rel="nofollow noreferrer ugc">Xometry Supplies</a>) you will receive <strong>two</strong> pieces, the second piece can be used as a setup piece. You only need to submit <strong>one</strong> test part for Xometry inspection.</li><li><strong>Finish - </strong> As Milled, Deburred and Oil-Free</li><li><strong>Shipping -</strong> Ground</li></ul><p><strong>Click here to view the test part files:</strong></p><p><a href="https://340051.fs1.hubspotusercontent-na1.net/hubfs/340051/%5BP%5D%20Partner+Supplier/Partner%20Files/New%20Partner%20Onboarding/Xometry%20Sheet%20Metal%20Flat%20Test%20Part%20Package.zip" rel="nofollow noreferrer ugc">Download Sheet Metal - Flat Test Part Packet and Drawings →</a></p><p><a href="https://pages.xometry.com/request-test-part" rel="nofollow noreferrer ugc">Request a Sheet Metal - Flat Test Part →</a></p><div class="blockquote"><div class="blockquote-content"><p class="blockquote-line">Can I change the material on the test part?</p></div></div><p>You will be sent the appropriate raw material for CNC - Mill, CNC - Lathe, Sheet Metal - Flat, Sheet Metal - Cutting, and Sheet Metal - Bent. </p><p>At this time, we only allow material modifications for the CNC - Mill test part. Delrin is an acceptable alternative material for the CNC - Mill test part, however you are responsible for supplying the material.</p><div class="blockquote"><div class="blockquote-content"><p class="blockquote-line">How long does it take to receive my material after requesting the test part?</p></div></div><p>Test part requests will be shipped within 2 business days via FedEx Ground. Depending on your location, it can take about a week for you to receive the test part material. You will receive an email with the tracking number for your material when it has shipped. This email will also include downloadable test part files.</p><h3 data-id="test-part-guidelines">Test Part Guidelines</h3><p>To simplify the process, we'll dispatch a package that contains a pre-cut piece of material for your test part, as well as all of the necessary instructions for fabrication once you request your test part. Look for your package in the next 1-2 days.</p><p>You will only need to complete one test part to be approved for any of the following: sheet metal (Flat, cutting, or Bent) and CNC (Mill or Lathe). For sheet metal and CNC test parts, you will receive an email after you request your test part and when your test part material is shipped.</p><p>You will be able to download the test part CAD files and inspection form from this email. All received test parts will be inspected by Xometry's quality team and will be retained for 30 days.</p><p><a href="https://340051.fs1.hubspotusercontent-na1.net/hubfs/340051/%5BP%5D%20Partner+Supplier/Partner%20Files/New%20Partner%20Onboarding/Xometry%20Sheet%20Metal%20Flat%20Test%20Part%20Package.zip" rel="nofollow noreferrer ugc">Download Sheet Metal - Flat Test Part Packet →</a></p><h3 data-id="inspection-report">Inspection Report</h3><p>To become a Xometry partner the test part must be shipped and submitted with an inspection report. You can download this report from the test part email or the link provided above. When you get ready to ship your test part, make sure to print out your inspection report and ship it with the part.</p><h3 data-id="finish">Finish</h3><p>The required finish for the test part is outlined in the Test Part Details table above. There are no additional surface finishes required. We will evaluate the quality of the part based on how you conform to Xometry’s Finishing Standards, as seen in our Partner Guide, and dimensional requirements (±.005”) of both the CAD model and bubble drawing. For any tolerance discrepancies, please revert to the CAD model.</p><h3 data-id="packing-and-shipping">Packing and Shipping</h3><p>Xometry has covered the shipping costs and provided a shipping label for you in the test part material box. Parts should be packaged according to the Packing Instructions and Guidelines as outlined in the Partner Guide with the provided packing list taped to the outside of the box, and the Inspection Checklist and Report included in the box.</p><h3 data-id="inspection-report-1">Inspection Report</h3><p>An inspection report is required for every job. Inspection reports can be handwritten or typed on the Xometry Inspection Report that’s attached to this document or downloaded from the Test Part Onboarding Guide in the Xometry Community. The test part inspection report should cover 100% of the dimensions from the CAD file and bubble drawing.</p><h3 data-id="whats-in-the-box">What’s In The Box?</h3><h4 data-id="your-material">Your Material</h4><p>The material required for your test part is provided by <a href="https://www.xometry.com/supplies/" rel="nofollow noreferrer ugc">Xometry Supplies</a> at no cost to you. This piece of Aluminum 5052 Sheet is cut to 6” x 8” x 0.125” as needed to fabricate your test part. If you have any issues with the material sent, complete the form <a href="https://share.hsforms.com/1JmIs04gfRK6IbIMTS-xd5A7adv" rel="nofollow noreferrer ugc">here</a>.</p><h4 data-id="test-part-packet">Test Part Packet</h4><p>This packet contains all of the instructions and details to complete your test part including how to get reimbursed for your part, the bubble drawing, inspection checklist and report, and shipping instructions to send it back to Xometry when you’re finished.</p><h4 data-id="packing-slip-and-shipping-label">Packing Slip and Shipping Label</h4><p>Everything you need to properly ship your completed test part back to Xometry including the Packing Slip and a Return Shipping Label.</p><h3 data-id="questions">Questions</h3><p>If you have any questions concerning the Test Part, please utilize <a href="https://pages.xometry.com/test-part-questions" rel="nofollow noreferrer ugc">this form</a>. This includes general inquiries, quality support, and technical support questions.</p><h3 data-id="next-steps">Next Steps</h3><p>I’ve finished my Test Part. Now what? Learn what to do after completing your test part:</p><p><a href="https://community.xometry.com/kb/articles/491-partner-network-onboarding#setting-up-your-banking-information-submitting-a-w-9" rel="nofollow noreferrer ugc">Read More →</a></p><h2 data-id="sheet-metal-cutting-test-part">Sheet Metal - Cutting Test Part</h2><p>You will receive an email with downloadable test part files when your test part material is shipped. You will need to request your test part through the link below in order to review the test part files. </p><p>Please note that it is a violation of our <a href="https://xometry-marketing.cdn.prismic.io/xometry-marketing/c1bb43ca-9bc0-46eb-b763-fb9a9a2f675e_Partner+Terms+and+Conditions+10+28+20.docx-2.pdf" rel="nofollow noreferrer ugc">Partner Terms and conditions</a> to subcontract out the test part.</p><ul><li><strong>Process - </strong>Sheet Metal - Cutting</li><li><strong>Material -</strong> Aluminum 5052 Sheet (Provided by <a href="https://www.xometry.com/supplies/" rel="nofollow noreferrer ugc">Xometry Supplies</a>) you will receive <strong>two</strong> pieces, the second piece can be used as a setup piece. You only need to submit <strong>one</strong> test part for Xometry inspection.</li><li><strong>Finish - </strong> As Milled, Deburred and Oil-Free</li><li><strong>Shipping -</strong> Ground</li></ul><p><strong>Click here to view the test part files:</strong></p><p><a href="https://340051.fs1.hubspotusercontent-na1.net/hubfs/340051/%5BP%5D%20Partner+Supplier/Partner%20Files/New%20Partner%20Onboarding/Sheet%20Metal%20-%20Cutting%20Test%20Part%20Package.zip" rel="nofollow noreferrer ugc">Download Sheet Metal - Cutting Test Part Packet and Drawings →</a></p><p><a href="https://pages.xometry.com/request-test-part" rel="nofollow noreferrer ugc">Request a Sheet Metal - Cutting Test Part →</a></p><div class="blockquote"><div class="blockquote-content"><p class="blockquote-line">Can I change the material on the test part?</p></div></div><p>You will be sent the appropriate raw material for CNC - Mill, CNC - Lathe, Sheet Metal - Flat, Sheet Metal - Cutting, and Sheet Metal - Bent. </p><p>At this time, we only allow material modifications for the CNC - Mill test part. Delrin is an acceptable alternative material for the CNC - Mill test part, however you are responsible for supplying the material.</p><div class="blockquote"><div class="blockquote-content"><p class="blockquote-line">How long does it take to receive my material after requesting the test part?</p></div></div><p>Test part requests will be shipped within 2 business days via FedEx Ground. Depending on your location, it can take about a week for you to receive the test part material. You will receive an email with the tracking number for your material when it has shipped. This email will also include downloadable test part files.</p><h3 data-id="test-part-guidelines-1">Test Part Guidelines</h3><p>To simplify the process, we'll dispatch a package that contains a pre-cut piece of material for your test part, as well as all of the necessary instructions for fabrication once you request your test part. Look for your package in the next 1-2 days.</p><p>You will only need to complete one test part to be approved for any of the following: sheet metal (Flat, Cutting, or Bent) and CNC (Mill or Lathe). For sheet metal and CNC test parts, you will receive an email after you request your test part and when your test part material is shipped.</p><p>You will be able to download the test part CAD files and inspection form from this email. All received test parts will be inspected by Xometry's quality team and will be retained for 30 days.</p><p><a href="https://340051.fs1.hubspotusercontent-na1.net/hubfs/340051/%5BP%5D%20Partner+Supplier/Partner%20Files/New%20Partner%20Onboarding/Sheet%20Metal%20-%20Cutting%20Test%20Part%20Package.zip" rel="nofollow noreferrer ugc">Download Sheet Metal - Cutting Test Part Packet →</a></p><h3 data-id="inspection-report-2">Inspection Report</h3><p>To become a Xometry partner the test part must be shipped and submitted with an inspection report. You can download this report from the test part email or the link provided above. When you get ready to ship your test part, make sure to print out your inspection report and ship it with the part.</p><h3 data-id="finish-1">Finish</h3><p>The required finish for the test part is outlined in the Test Part Details table above. There are no additional surface finishes required. We will evaluate the quality of the part based on how you conform to Xometry’s Finishing Standards, as seen in our Partner Guide, and dimensional requirements (±.005”) of both the CAD model and bubble drawing. For any tolerance discrepancies, please revert to the CAD model.</p><h3 data-id="packing-and-shipping-1">Packing and Shipping</h3><p>Xometry has covered the shipping costs and provided a shipping label for you in the test part material box. Parts should be packaged according to the Packing Instructions and Guidelines as outlined in the Partner Guide with the provided packing list taped to the outside of the box, and the Inspection Checklist and Report included in the box.</p><h3 data-id="inspection-report-3">Inspection Report</h3><p>An inspection report is required for every job. Inspection reports can be handwritten or typed on the Xometry Inspection Report that’s attached to this document or downloaded from the Test Part Onboarding Guide in the Xometry Community. The test part inspection report should cover 100% of the dimensions from the CAD file and bubble drawing.</p><h3 data-id="whats-in-the-box-1">What’s In The Box?</h3><h4 data-id="your-material-1">Your Material</h4><p>The material required for your test part is provided by <a href="https://www.xometry.com/supplies/" rel="nofollow noreferrer ugc">Xometry Supplies</a> at no cost to you. This piece of Aluminum 5052 Sheet is cut to 6” x 8” x 0.125” as needed to fabricate your test part. If you have any issues with the material sent, complete the form <a href="https://share.hsforms.com/1JmIs04gfRK6IbIMTS-xd5A7adv" rel="nofollow noreferrer ugc">here</a>.</p><h4 data-id="test-part-packet-1">Test Part Packet</h4><p>This packet contains all of the instructions and details to complete your test part including how to get reimbursed for your part, the bubble drawing, inspection checklist and report, and shipping instructions to send it back to Xometry when you’re finished.</p><h4 data-id="packing-slip-and-shipping-label-1">Packing Slip and Shipping Label</h4><p>Everything you need to properly ship your completed test part back to Xometry including the Packing Slip and a Return Shipping Label.</p><h3 data-id="questions-1">Questions</h3><p>If you have any questions concerning the Test Part, please utilize <a href="https://pages.xometry.com/test-part-questions" rel="nofollow noreferrer ugc">this form</a>. This includes general inquiries, quality support, and technical support questions.</p><h3 data-id="next-steps-1">Next Steps</h3><p>I’ve finished my Test Part. Now what? Learn what to do after completing your test part:</p><p><a href="https://community.xometry.com/kb/articles/491-partner-network-onboarding#setting-up-your-banking-information-submitting-a-w-9" rel="nofollow noreferrer ugc">Read More →</a></p> </article> </main>
