You will be sent the appropriate raw material for CNC - Mill, CNC - Lathe, Sheet Metal - Flat, and Sheet Metal - Bent. At this time, we only allow material modifications for the CNC - Mill test part. Delrin is an acceptable alternative material for the CNC - Mill test part, however the Partner is responsible for supplying the material.
