When a print is provided with the parts, it must be ballooned (by hand is acceptable) to correlate with the inspection report. Regardless of order quantity, 100% of all dimensions, attributes, dimensional locations, and print notes must be documented for the required sample size (See Statistical Sampling Table below ).
If not already on the print, the following needs to be checked and entered onto the Xometry inspection template:
- Correct material to drawing spec
- Material test reports if required
- Plating and certification
- Surface roughness (125 or better unless noted)
- All inserts are installed correctly
- All parts are deburred (as per print requirement)
- All parts are clean and threaded holes do not have chips packed in the bottom
